Material editing
Hello
I’ve upgraded to V4 .
I can not edit materials like before.
1.If I change the color of the material in Sketchup I can not see the changes in enscape
  1. I tried to play with a texture in the roughness slot darker or brighter but the texture is not displayed and the slider doesn’t have any affect on the material
Have you got the sync enabled on the enscape tool bar?
Yes it is enabled. I had to load again the texture in Enscape so I can see it. As for the green plaster , usually when I changed the color in Sketchup I was able to see it in Enscape but this time I had to fade out the texture in Enscape to see the colour from Sketchup.
@ADDITIVE , thank you for the report right away.
First things first, does this issue now still persist? I’m not able to reproduce this problem on my machine I’m afraid, so if you still run into this could you kindly provide me with a report as usual?
Please also let me know once submitted so that I can have a look right away to also forward to our developers if required.
Thank you again once more.
It seems like that behaviour it’s gone (for the moment) . I will provide a report next time.
Thanks!
