Material issues
I am having trouble getting the correct UV tiling on objects. as well as self illuminating materials.
Now I can increase the size of my uv shells which works. Seems vantage doesn’t transfer over the uv tiling from MAYA.
This method doesn’t work if I have a logo on fabric which I need the UV at a 1 to 1 space. while the bump maps of the fabric I need at like 50X50.
Is there a way around this? Do I need to increase my shell and use a decal node instead for the logo? Does the decal save correctly in the vrscene file to be transferred over to vantage.
Also How do I go about illuminating an image in vantage? Like a TV or a large projection screen. Vray light maps aren’t being read correctly in vantage.
Hi Antonio,
Can you please send us a sample scene so we can investigate it?
Alexander
Do you want a vantage scene file or the vrscene file?
It seems a .vrscene file should be enough. A Maya file is also ok, so we can check the original setup.
Vantage doesn’t support decals at the moment.
As far as I know, this should correctly. Can you send us a scene for this too ?
Greetings,
Vladimir Nedev
Sure…how can I send you the file?
You can send it to my e-mail : vladimir.nedev@chaos.com
If it’s large you can upload it to some free service and send me the link.
Please mention what the issue is in your e-mail, maybe a screen-shot with the problem area circled.
Greetings,
Vladimir Nedev
