This is my exprerimental between Vray VS Corona
I’ve rendering a meeting room Scene with vray in 10minutes
so I tried to render with corona … and this is the result
But in the corona version scene have a not correct shaders and render setup!
its sad to see that the noise in corona lets it down. ive converted most of my archinteriors scenes to corona and the problem remains the noise within a short time given for a complete render in vray.
for your meeting room:
to buttress the discussion: left is vray in 9mins from max no pp. middle is corona from max. right is corona photoshoped.
you can analyse n let me know what you think.
Note: # very talented artist are welcome to help ,advice and give tips
Apparently Corona has lots of more noise than scanline in the same time. ![]()
YES!
Also who wants that silly CaUSticS?!
Worst comparaison I’ve seen so far lol. I will do one myself to show you a good comparaison, corona is just better… when you can tweak the material well and the gamma… at equal quality , Corona is faster then Vray.. and with always a better quality ^^
what is great about comparisons is that you can always make one that supports your opinions
just look at the furryball ones ![]()
I looked at it and yeah, haha so true!
first of all - my post is aimed at the possible challenges a mid-level artist may face using corona. its merely a referencing than it is a comparison.
Bigguns - i would like to see you do a better comparison that we can learn reasonably from… whatever keymaster meant by “furryball ones” is just laughable not entirely contributive so since most of us are here to learn a thing or two about corona, i sure cant wait to see your contributions. thank you.
keymaster - “what is great about comparisons is that you can always make one that supports your opinions”. (not quite what i expect from the founder but thank you for this wonderful renderer)… instead, i was hoping you could tell us what critical settings to work with to improve the quality of our renders and knock off the noise significantly? ![]()
well since I’m not in it for the money I have no need to bullshit anyone ![]()
about the render: There are probably some things that could be done, tweaking sampling amount of light solvers, random sampler, more efficient materials, etc., but really, if you use portals for the environment light and HD cache, you are very near the optimal solution. It is natural for path tracing to have some noise after 10 minutes in interior.
PS: just in case, I didnt mean it that you fabricated the results, just that the results in different scenes/settings vary wildly
Thanks for your advice sir
well …
maybe I must learn again about corona .. beside shader … I must learn how to work fast with corona with get better result… ![]()
noe2arch … youre welcome Sir… also take note of keymasters tips, they are necessary processes for optimizing quality n speed in corona
