Another day another problem.
My node is reporting a missing texture plugin. I’ve narrowed it down to the Forest Color/Forest Edge maps from Forest Pack.
The only issue is that the plugins are there on the node and on the host machine. Definitely there. Not missing. The same versions on both machines.
The only difference between the machines is that Forest Pack is installed as a node license on the node and a Workstation license on the workstation.
Not sure if this a Corona issue or an Itoosoft one?
DR Server isn’t running as administrator either.
