The Wetting effect is a very useful addition — nice work.
It works well on the ground and other horizontal surfaces, but it feels quite limited on large vertical surfaces, especially building façades in my case. On vertical surfaces, the wetting pattern seems to use the same random noise distribution as on horizontal ones, without any sense of gravity. This makes the result look quite unnatural.
At the moment, the choice is basically between applying full wetting to the façade, which can make the whole building look oily, or excluding the walls entirely.
Ideally, vertical surfaces could have a different wetting behavior, such as a subtle darkening from dampness, or a Z-axis-based gradient where the lower parts are wetter and the effect gradually fades upward, rather than showing puddle-like wet patches that appear to ignore gravity.
Are there any plans to make the Wetting effect more flexible for vertical surfaces in future updates?
