I have found out after long research, that I can only store all channels into a file at the “Vray” Tab > Frame Buffer “Vray raw image file”.
Does it mean that the “save as” in the Common Tab is obsolete?
I don’t understand why this is not all at the same place and better explained ![]()
And then I’m getting a warning, because I have disabled the standard common output:
I had basic “common” output (Render Output > save file) unchecked.
