hi evryone
i modeled my room and rendered it to improve my interiors.
the scene has one direct light as a sun (mult. 3), skylight (mult. 2) and no interior light (i wanted the morning atmosphere, as it is when i get up. besides, i wanted to test the ability to light a room mainly with GI).
there is a vray light in the large window, set as skylight portal (when it was set on vray light the soft shedows it caused were better, but the intensity was to bright and the decay to quick).
render settings:
first bounce and second both on mult. 1
first bounce: -3,0 HSph 50, Interp. 50, all thresholds on 0.3.
secondary bounce on direct computation, subdiv 7 depth 10.
i gave up on the color mapping to brighten the dark spots because it seemed to wash out the colors. so i photoshopped it.
here are both images before and after photoshop.
ir map was calculated with all the glass elements hidden, and then re-rendered with them.
critics or guidance about settings etc are more than welcomed
noam
Actually arch vis is becoming pretty widespread, and almost anyone can do or will be able to do it in a couple of years. True artist will have to learn from photographers in order to make 3d masterpieces.
Photography and 3D are undissociable since the beginning imo, 3d is obeservation, photography is observation, 3d is capturing mood, photography is capturing mood etc… My opinion
I’d go with the un-photoshopped one. Just add some nice glossies to your materials to get more definition. Should make it even more life like. Make sure you set glossies for rough surfaces like the painted wall as well, and keep them really low like 0.2 or so for these types of surfaces. The floor should of course be slightly more shiny.
thanks evryone for the compliments and good ideas.
trixian: sounds good and i’ll check it out. but wouldn’t it pump up render times increadibly? i’ve also thought about increasing GI emitting and recieving for the walls…
chris-x & dusan: i couldn’t agree more. i’m also into photography myself…
stellar: in real life those little le-courbusier armchairs do look redicilously small next to the huge aeron chair…
due to requests i post the scene here, so you can check out the settings. any comments about the settings will be greatly appreciated, since i’m a bit new to this indoor stuff and i’m sure i have a lot to learn…
Nice work Background fits in perfectly with the scene. Just need to add in the rest of the pc. Have never tried using Max without a mouse or tablet but I’m sure it would be pretty painful.
since i did this on my spare time, and i was in no hurry, i rendered the IR in the final resolution: 1024x768, and the settings are pretty high (in my opinion).
the IR map calculation took a few hours (have no idea how long exactly, when i woke up it was done). the render itself wasn’t too bad, perhaps 1 hour (but i really don’t remember for sure, so don’t count on it). if you have any idea about how to reduce rendertimes and still have a reasonable image, i’de love to hear, that’s the reason i posted this image to begin with.
p.s. - perhaps your scene rendered diffrently because you calulated the IR map with all the glass elements. try hiding them (all the objects named “glass XX” and calculate the map, and then showing them and render with the same map.
As i mention before…the rendering on the file was too long..so i change it..now it takes 14min to render 512*389…but it has not gone thru any photoshop editing. Not as good as your setting though…
reza: when you say “render time” do you include the IR map calculation?
anyway, i’de love to hear about the changes you’ve done. after all - i posted the scene and the post for people to share opinions and techniques and for evryone to learn, mainly me
about the settings: as you noticed, the shades element in the window (mainly the closed one) has many ugly splotches if the settings drop, like in your case. that’s the main reason why my settings are so high.
i don’t know what machine you’re using, but i believe there is a difference between ours, and considering the machine’s specifications, the difference in settings and resolution, it’s a reasonable time difference.
but please share your thoughts…
ok..the machine im using is a dual xeon 3.06 with 1mb cache…what i mean by render time is the total time it takes including IR map calculation. Currently the machine is rendering your model with your settings..ill post the image as well as the settings…thank you for sharing your model..by the way..i never hide any of my objects due to calculating ir maps.
the reason i always freak out when rendering times are high is because i do a new project ever 2 days or so…so modeling and rendering is 2 days max..
Rendering time for 1024*768 is 37 minutes
