Need Assistance with Vray Render Error - "Cancelling GPU rendering!" and more
​Hi Everyone
Lately I have been working on a project of mine.
Since 2 days ago I started to get the same 3 errors in my projects which I attached as screenshots.
I tried many methods, including re - installing Vray, Checked my Driver version of the GPU, changed Vray render Options…
Nothing worked for me…
I also checked other projects and the issue seems to happen there too, which it did not before…
**Attached the download link of the the project in case of need.
Can I get any assistance?
Thanks!
Project For Check.zip - Google Drive
I am receving similar error “Could not allocate device frame buffer…:” error since update to VRay 5 (Maya 2020) in almost every scene.
You may be running out of VRAM. Check your GPU memory usage through a third-party software such as GPU-Z and see if that is indeed the case. If so, you would need to optimize your scene (lowering texture resolution, lower quality displacements, etc.).
This seems like it is a VRAM issue,
I Optimized all the textures, seems to work for now, if something will happen again I will update, Thanks for the Assist!
