Need help with creating carpet material
First of all,
I would like to say hello to Corona users.
Guys I have a short deadline for my interior work and I am struggling with carpet material like this one attached to this message.
I would be very thankful for any help.
Marcin
Maybe this van be of any help
Questions about this type of material pop up from time to time. No wonder, since it’s really tricky to setup. I would either recommend using hair and fur or CScatter (if it has to be 3d), or following Juraj’s guides from this post(if it can be just a material): Juraj's Renderings thread - Corona Common :: Gallery - Chaos Forum
Honestly it can’t be done convincingly by scatter (with direction) or hair&fur. Hair&Fur should just be left alone, it looks terrible in 99.9 cases.
The best look in this particular case is also the simplest, most straightforward solution : The very exact photo of this carpet in this state from top, plus displacement (of any repeated pattern, not B&W map of this texture)
Thank you guys for support I will do my best.
Best Regards,
Marcin
Hej marcell86,
there was a post some time ago about it.
I hope the link will work (just copied it from my browser).
You can take a look at my result.
It wont work in animations I think, because the micro-reflectance of the carpet is faked by a map.
I hope it will help
best regards
Nico
Is this what you are after?
thats exactly what I am looking for
Hope somebody 3d scans a bunch of those rugs, its the trickiest little things to make!
