Needing help with materials in Enscape
I am having this issue with Enscape..
in sketchUP it looks fine but when Enscape renders, not so much..
I get it is not perfect in sketchUp but its close enough the client would understand the material.. but when Enscape finishes its not recognizable..
Thoughts?
I’d recommend using the plugin “ThruPaint” to add correct texture mapping to your object.
or SketchUV
also, check if the faces are oriented corretly or reversed
