New vantage user: My textures are not transporting into vantage??
I have been using vray for sketchup for the past 8 years. I am trying to use Vantage, but am having issues. When I run a “live link”, the model imports successfully into vantage, but does not include any textures. When I click the “materials” tab on the right nothing is there. What am I doing wrong? Attached is the view rendered, as well as an additional view, as I can see it in vantage. Anyone have any ideas for me? Thank you!!
Are the textures on a network drive?
Could you share the log file: %APPDATA%\Chaos Group\Vantage\debug_log.txt ? Note that it will contain file names. You have to load this scene before copying the file because it’s overwritten each time you start Vantage.
Hi Nick,
This is expected and is a current limitation. When in Live link the Materials, Objects and Lights tab will be empty, without content(except for the environment section in the Lights tab). If you export a vrscene and load it in Vantage, those tabs will be properly populated.
Alexander
Thank you!!! I appreciate your help!!!
