Since some of the last vray update I noticed that some textures are not displayed in the viewport. When opening a scene in c4d, random textures are not displayed. Sometimes this texture, sometimes another. I thought it was something with the textures I created, but now after reopening the scene, the textures from Cosmos are not showing up. Interestingly, the same textures render correctly in c4d, but wrong in Vantage with live link.
C4d to Vantage will hands over only give a uvw mapping over probably your symbols have no uvw mapping.
Ok, but I haven’t changed the scene for a few days, and yesterday when I loaded it, the trees that are from Cosmos worked fine in the live link. But other textures, one of those used on the building, did not load well.
Hello @Makushimu
The pink color in Chaos Vantage means that a feature is not supported, which could be the case here. Can you please check that you have used any shaders that are not supported by vantage?
You can check the supported features list at the Chaos Vantage Cinema 4D supported features documentation.
