Has anyone had this issue before, the problem might not even be Vray but shows up strongly on SkinSSS2 shader.
I found it’s coming from the refraction and specular layer, btw.
Can you post that scene along with the normal map?
What software did you use to generate normal map ?
What Vray/Max version are you using ?
