Object created in SketchUp only appear in white in Enscape, what’s gone wrong and how to fix it?
Please refer to image attached as example.
Image that You showed.. Where is the lady with the bag in ENS window gone..? She is next to the circles in sKetchup but not in ENS. are You sure Your camera is showing the same geometry in both windows?
Can You show material settings of those which You have applied to those circles.. Are You sure You didn’t give any luminance to it.? You have not standard sky settings? Some HDRI ? if it is a dark image (not every HDRI out there is correctly made) renderer can try to brighten it so much everything else will be just shining white..
But my guess is that You just applied a basic sKetchup materials to it and didn’t adjust any settings in ENS material editor. The basic sKetchup texture goes to ALBEDO which is to bright. I usually darken it to 75 percent if I don’t have to use a specific PBR textures. in sKetchup window it look like You have some transparent material on the top circle.. straight from sKetchup it will have some 50% transmittance which will make it look pretty white on this angle anyways..
So are You knew to ENScape or generally new to rendering.?
There is many things that can be set wrong. simply saying.. “I have problem” giving confusing image.. and asking “how to fix it”.. is not always going to work.
If You knew to ENS just have a look at knowledgebase. Someone may help You with this problem, but judging from fact that You had a problem straight on turning on ENS and applying first material.. You will need that knowledge from knowledgebase..
