opacity map with sss shader
hi I tried to make a leaf with the VRAY SSS SHADER and an opacity map
but I did not reach this effect.
IS there a way to do that??
thanks a lot
try using the 2sided material
The sss shader requires that your object has some thickness. If it does not, you’d better use the VRay2SidedMtl material.
Thanks a lot for your answers Jacksc02 and Vlado !!
