PheonixFDOceanTexture direction
So I have connected the PFD OceanTexture to a poly plane and all is looking well. The loop animation is flowing in the -x and I need it to flow in the +x
How do I change the wave direction?
Thanks for any help
Hey,
Just rotate the placement node for the Ocean texture.
Oh, so you don’t need any simulation, foam, splashes? Then yes, you can just displace a plane indeed.
Thanks Guys. I went down the route of just using the oceanTexure plugged into a plane just so we could get the job out in time at 7K render (not animated) with camera overrides rendered on the Cloud.
We will need dynamics for the next animation shot so learning that now…in HD only, phew!
