Phoenix FD RC is on the site. We have a couple of new features:
- Phoenix FD for Maya help with the installation (still not available officially on spot3d)
- Wavelet turbulence on second pass (i.e. to increase the resolution on existing simulation)
- simulation of particles, foam and splashes on second pass
- tweak parameters/add new output channels on second pass (depending on the parameters the result may be not physically accurate, or correct at all)
- discharge modificators that can controll discharge, temperature, smoke, fuel, velocity and particles emission based on some parameter of the source - it’s speed, position, normal and random in world, grid or object space.
- new improved method for interaction between Phoenix simulators, i.e. the “cascades” method.
- a sample how to use PhoenixFD with DMM
- ability to change the default cache path. Also right click on the open button now shows the available caches in the current path (for quick navigation)
Here is the change log:
Rare crash with the OpenGL preview
Crash when emitting from particles that are dying inside the simulator
Crash with liquid simulation with fuel channel, when the fuel is not set as output channel
Wrong emission when using 2 face sets from one rigid body
Random crash when stopping the simulation
PhoenixFD texture is not working properly with motion blur
Air field do not work properly with the simulator
Can’t enter a negative gravity vector
Camera projection mapping during simulation is not working
Wrong per particle radius with particle sources
Restore resimulation from base simulation cache if the velocity channel is not present
Waiting mode for the resimulation
Reduce the GPU memory consumption when using diffuse lighting
PhoenixFD must be installed in its own directory
Ability to restore the simulation in batch mode
Option Var to run PhoenixFD in “safe mode”
Resimulation of fluids with optional wavelet turbulence
Resimulation of particles
Installer must include option to install offline version of the help
Option for direct transfer when a simulator is used as a non-solid source
Ability to specify custom default cache path
