Preset Rendering Options - What's included in ENVIRONMENT catagory?
When you go to load a preset in the Render Setup, and you only select ENVIRONMENT to load, exactly what is being loaded? I had a scene in which I did a test render and everything was blown out. I went to my previous version, which was fine, and saved the settings as a preset.
I then went to my problem file, and loaded that preset - but only selected environment. That solved the problem, but I cannot detect any changes anywhere!??
Tnx
These are the settings under the Environment Rollout:
Oh, I always thought “Environment” would load/save the stuff in Max’ own Environment dialogue (like Background color, Exposure Control, Environment effects like VRayToon…)
V-Ray presets store only V-Ray rollouts settings, 3dsMax environment dialog is handled by 3dsMax Presets:
Oh, I see… we’re still on Max 2014, and those screens look nothing like my render setup window :wink:
Those options are available in the Max 2014 as well:
I know… it just didn’t look like it did in your earlier screens :wink:
