At the moment, i’m working on a kitchendesign. The materials that i used are dark and black.
If i render this with enscape is this not good, , I see black boxes because there is not enough light, can someone help me, of give some advice how t fix this?
I also tryed with spotlights en spherelight, it’s to dark for rendering.
grtz
Hans
@HansGielen1980 , did you actually use black materials for the interiors or is this unwanted entirely? Can you please share a screenshot of the material settings for me, and are you making use of our material editor? And, which GPU (Graphics card) is built into your system?
Hans, are you using 100% Black? If so, make it a bit brighter. You should never use 100% Black and also not 100% White. The first topic in the following video-link shows why.
Video from SketchUp UK, Adam Fairclough: https://www.youtube.com/watch?v=itRqfy9c5kc
Greetings, Peter
