Procedural textures using Vray GPU not working
I am trying to add some procedural textures to my vray material, but it won’t render inside my vray framebuffer. The CPU is working without any problems. For this example I am using a Vray material with a VrayTriplanarTex and Speckle inside the diffuse channel.
I am using the vray_79910_max2027_dr2_x64_experimental_33718.
Speckle is one of those textures that are baked for GPU. Switch Speckle’s source mapping to “Explicit Map Channel” (and adjust the triplanar), and it should work.
