Proxies
Hello, how can i load Corona proxies in project? all at once. Thx
I find it best to save out sets of proxies into their own .max files then you can import/merge a group of related proxies at once.
For example 1 .max file for all Vitra range furniture as corona proxies - merge and bring in specific models or all models as needed.
Hope that’s helpful.
J
Same here. Biggest advantage of saving proxies into max files, is that you retain assigned materials. No need to save/load mat libraries separately.
but i am looking for something different, when i work with scene in work and bring it home, on my home PC all the proxies looks like square with cross_see on pic. , i must manually click load for all the proxies anf set the path to *.cgeo files
Then you simply need to relink paths. Relink Bitmaps to the rescue :]
thx, go to try it.
and what about saving all proxies from the scene, resource collector collect only textures, but how can i collect proxies? thx
I would recommend Collect Asset 2 script, it fully support Corona, including proxies.
thank you so much.
You’re welcome!
