proxies - material management
hi there,
whats the proper workflow for use with proxies and the materials?
i was hoping corona proxies inherit the materials an maps used :confused:
so what is the suggested solution - saving the material lib from the object the proxie is made of with the proxie itself?
i have already searche dthe forum and also in the net but i could not find any comprehensive how to relating to this …
would be cool if someone could share some workflows and ideas
thanks,
greetings bsfranza
The only thing I can think of is to sample the material from original object and assign to proxy. But this is impossible if you are loading a proxy into a new scene. So we would like to export proxy+material. If this is possible, I think it could be a nice feature request. Go ahead and add it. :smiley:
Usually a proxy is reused for different projects and they have something in common so it makes sense to collect them in a max scene. For example trees/cars: Make ONE scene “car_corona_proxies.max” where you store all your car proxies(!) with the proper material assigned. For a new scene/project just merge the proxies you need from there instead of using the “Load from file…” button of a newly created Corona proxy.
This has several advantages in material handling also: You can have a “red”-car-proxy “green”-car-proxy “blue”-car-proxy in your “car_corona_proxies.max” file sharing the other materials except the basic car paint. Same goes for trees/foliage etc.
I´d only wish there was some way to get all those mrProxies we have converted without messing around with the original data :-/
Good Luck!
