The reason why materials are not loaded with proxies is simple - that’s because materials aren’t saved with proxies. That’s how proxies are designed and it’s not a bug. This might, or might not change in the future, but for now, if you want proxies with materials, your best option is to save them inside Max file and merge them to your scene from there when needed.
Hi, thanks for your answer.
So, lets say. I can add any objects into my scene and convert them to corona proxy. Save them in a proper folder.
I can not load them directly from those proxy folder, but instead i can copy or merge proxys between scene files.
Is that correct?
I am starting a big Master Plan site project. We need to optimize a lots of file parts that will be added into a Master 3ds max File.
We have: Buildings + Streets + Cars + Trees + Project Architecture.
Made those files, like cars, peoples, trees with corona proxys.
Then i will use Xref Scene to insert them inside Master 3ds file.
Is this a good method?
Should i change any thoughts here?
Not sure what you mean by “save them in a proper folder”, but no, you absolutely can load proxies directly from proxy file, it’s just you will not be able to transfer materials that way. If you want to retain materials, then saving proxies inside max files and then merging them in to your scenes from there, is the easiest way. Alternative is to save mat files alongside proxy files and load materials separately, but i don’t think that’s very convenient workflow.
Well, if you’re planning to use xrefs, then using proxies makes little sense, you’ll hardly get any benefit from that, but instead you will have to sacrifice half of the xrefs’ benefits. On the other hand, i only have experience in using xref objects and not xref scenes, so there might be some things that i’m not aware of, so do your own research before deciding what’s best approach for you.
Proxies are geometry files like OBJ, FBX, etc. They do not store bitmaps or information where to find them. I would suggest creating a “library” scene with multiple assets and then merging assets from this library scene into your target scene.
It would be definitely nice to have the ability to store own assets in Cosmos.
But can any one explain a little better; (despite this matter will probably get away from this topic); a good method workflow to make big complex scenes in Architecture Master Plans, like (small city parts, with all assets important to it: trees, bushes, grass, terrains, streets, vehicles, buildings, surroundings, and the architecture project itself).
