I want to share my new retail project called R1.
https://www.behance.net/gallery/50801437/R1
Best,
Yura
Best,
Yura
Hi, nice job, very photorealistic! Can i know the parameters of the Corona sun?
thanks!
Thank you!
sun size only 1? I wanted to know because you always get a nice soft effect
great mood,lighting is awesome.
is that corona dof?
Sun is 1. It needed only for that building on the background.
Corona DOF, right.
Really cool!
Lighting/shaders/compositon..
And wat’s in environment? ![]()
Any postprocess?
@fabio - at that scene i used bigger sun. Look at the attachment.
@shadowman - fully modeled environment and HDRI map. Postprocess is simple, just curves to make shadows and whites looks more cool. Also Corona bloom (not much, like 1-10)
thank you and congratulation again! ![]()
GREAT! realistic looks but why is your sun intensity 0.01 ? why is it so low, did you use a hdri with it in environment or only in reflections because i can see you didn’t use the “add corona sky to environment” button on the corona sun light parameter dialog box?. i would like to see how you played with the vfb tone mapping settings to achieve this result in your images.
great looking stone textures, where did you source them from?
