Rhys
March 20, 2007, 10:23am
1
Trying to render a masterplan. Has lots of xrefs including trees and cars.
The scene opens and uses 2.2gb of ram. I have a total of 4.
I select render to vray file. and as it starts to do the prepass the ram jumps upto 4.85gb. The cpu seems to then be limited to only 25%
The virutal memory in task manager shows max using 4gb. But real memory shows only 2.8gb.
System specs
2 x 5160
4gb ram
x64 windows
x64 max
x64 vray.
vlado
March 20, 2007, 10:50am
2
It may be that Window is swapping some of the memory to disk. It may also happen if you are using VRayProxy files and/or displacement and you have too low Dynamic memory threshold.
Have you disabled the “Render to memory” option in the V-Ray VFB? Also, additional memory can be saved if you set the 3dsmax resolution to be something like 320x200 and use a different resolution for the actual V-Ray VFB.
Rhys
March 20, 2007, 11:39am
3
Whats a good figure for the dynamic memory threshold ?
I’ve disabled rendering to any frame buffer, and just save out as a vray file. Seems to be working at the moment ok. Rendering at ram usage of 4.28gb.
Trying to find the link the vrayimg file gui program seems to be down, anyone have a mirror ?
Rhys
March 20, 2007, 4:02pm
4
Just tried rendering again, This time its only using 25% cpu again.
Very frustrating. Any other suggestions ?
vlado
March 20, 2007, 5:12pm
5
Well, here are some suggestions:
(*) make sure that the Multithreaded option is checked in the Customize menu in the Render tab - it is in the habit of turning itself off sometimes.
(*) to determine if it is a disk swap issue, try to delete some geometry and see if it helps.
(*) make sure you are NOT using the bitmap pager in 3dsmax.
(*) to rule out any bitmap problems, you can try to assign a grey material to everything.
(*) make sure you are using “Static” default geometry in V-Ray System rollout.
(*) if you are using any VRayProxies, displacement, VRayFur, try to disable them and see if it helps.
(*) try a different scene and see if there is any difference.
Rhys
March 20, 2007, 6:59pm
8
[EDIT BY VLADO] Lots of log file here…
Rhys
9
Rhys
March 20, 2007, 7:00pm
10
well that was abit silly.. half a million pages of bloody vraylog.
Please edit your posts and upload the txt file somewhere.
lol, that is my favorite post ever on any forum anywhere. :o
CCS
March 21, 2007, 1:50am
13
Oh my.
BTW, can anyone post the exact value of pi for me?
vlado
March 21, 2007, 6:53am
14
It would have been more appropriate to send the entire log to me at vlado@chaosgroup.com as the most important parts (sd tree statistics and memory usage) are missing above; the parts above do show that there is a lot of geometry in the scene, but you mentioned this already.
Rhys
March 21, 2007, 9:48am
15
appologize about that post, had a few forum php errors. Deleted the posts yesterday when i saw what a mess it was, must of not updated.
I’ll email you the vray log.
Rhys
March 21, 2007, 12:29pm
16
ok if i override the textures with just a solid color it renders at 100% cpu
and when i enable the texture it doesnt. Now the texture the only bitmaps being used is on the cars.
So i turned the car xref off. But still no luck didnt render at 100% All the rest of the materials are just colors. no bitmaps.
Any ideas?
Did you restart max after turning the x-refs off, if not their maps were probably still in memory or you could type freescenebitmaps() in the listener
Just sounds like your scene is too big, you should look at breaking it up into layers and comping it together
Rhys
March 21, 2007, 2:06pm
18
I’ve found what it is now.
It doesnt matter which xrefs i turn on. All will render fine by themselfs.
The problem is as soon as i go over 4gb of ram. It only renders at 25% cpu. Rendering the vrimg file helps.
Has anyone else experianced this at all ? Anyway around it ?
hmmm, weird, what hardware are you running?
I would assume its something like as soon as you breach your physical memory limit you start paging to disk which is dead slow compared to RAM, so therefore the whole process slows down to keep up with the speed of the disk?
Other than trying to lower your memory usage or by more memory you might be stuck.
