Hi guys not sure if this is a problem with corona or with rebusfarm, but the new version won’t work. When doing the smartcheck it hangs on Checking:CoronaRenderer A7. I’ll post it to them as well.
Troy
Troy
Corona A7 is really old version - what does it say exactly (screenshot)? do you have the latest rebus plugin installed?
Hmmm, shouldn’t A7 be non-functioning by now?
Yeah same issue here, imho it’s just what the farminizer writes as generic error and the issue is they didn’t update to 1.6 yet. Usually takes them at least a week.
Same problem here, ayone has solve?
I got this message from Rebus:
"Hello,
this version is not yet supported on RebusFarm, you should stick to Version 1.5 in order to render with RebusFarm
best regards / beste grüsse,
Marco
rebusfarm.net"
1.6 should now be supported on rebus
I also received a message that CXR is now supported by Rebus.
