Here is a render trying to recreate the same mode from the photo. This is the closest I could get. I wish there was a way to get more dramatic light similar to photo with more contrast, darker shadows etc.
If someone like to try, -here is the model
Which one is photo!? ![]()
Already very close! I think it would look even better if the sun would come from the window on the plant. Then you could also get the subsurface effect.
Really cool!! Personally i would adjust the point and angle of vue, too much distortion in the sides of the images.
Thank you Jeffrey. Darn close! I think yours are much closer. Please show settings. Alexander Thank you.
@deegobt , I modelled using photomatch in SketchUp thus the distortion I think.
@Thomas_Willberger Thank you ; ) Tried adjusting the sun, even turning the model 180 degrees but couldn´t get the dramatic light/shadow mode. Maybe a good crisp HDR would give better results.
Anybody else wanna give it a go?
Hi, happy that you like the result,
the major changes are:
New try. Found out the outside image blocked the sun. Made it transparent. Followed Thomas advice and adjusted it to reach the plant + added some fog
I think the mood is closer now. Uploaded a video aswell:
