Sun size - Render as a physical model
Hi, I am wondering if there is a way to make the sun bigger so that the render will look more like a physical model. I use this in Vray and would be great to see the same in Enscape. I have attached two picture to show the different shadows.
Are you guys planning to realease a photo studio like environment ? I find very hard to make model like renders with ensacape. By the way the new parallel projection view is great!
@damndami , welcome to our forum and thanks a lot for your post.
You may also want to go into the Atmosphere tab of our Visual Settings and reduce the shadow sharpness to get closer to the result you have on the right rendering - plus, here you can also increase/decrease the sun brightness at least to your liking.
Finally, you may then also import a black skybox as your background. :slight_smile: This should get you similar results already.
