Reflection end at simulator
In my render the oceanmesh is not showing in my reflections. Is it a parameter or switch I have to turn on?
Hey,
This happens as the ocean mesh is built only in the camera view. In order to fix this you can increase the Off-Screen Margin option in the Rendering rollout of the Phoenix simulator. You can find more about it here - Phoenix for 3ds Max
Note that increasing the value too much will consume much more memory, so increase it gradually.
Cheers!
Thank you very much for the quick response! Will enable it.
