I have an underwater scene I’m creating, and have a VRay Material that has refraction, but NO reflection for the water (so it will refract the sky). But for some reason, it’s reflecting the ground surface under the water. I don’t understand why this happens. Can anyone help? Is this normal?
OK this is a simple representation of the scene, with procedural materials. One render is with the water “on” and one with the water “off” The one with the water “on” reflects everything on the ground, and the material assigned has a black reflection, and white refraction.
I checked the file, redid the shaders (the scene you shared had some complaint about missing maps/shaders), and got precisely your result.
In fact, i added reflection and refraction REs and i got the refractions to show up in the reflection channel, not the refraction one.
I’ll test a bit more today to see if there’s anything obvious i missed, and if there isn’t i’ll file a bug report and let the pros deal with it
Whether it’s a bug, or it’s expected, i don’t quite know right now.
However, flip the top plane (water) so its arrow points down and all will be as you want it.
