When I’m using the Frame Buffer, my render looks like this:
(Ignore the noise, super quick render)
then when I turn off “Enable built-in frame buffer” in the render settings under “V-Ray”, it turns to this:
It’s basically pitch black, why aren’t they the same?
Hi with just these two screengrabs it is impossible to tell for sure. I place my bet on exposure correction in the VFB. Here is a bit of info about it - V-Ray for 3ds Max
We will need a bit more info - at least widen the screengrab a little so it is visible if you have additional active layers in the VFB or if you have changed your display correction.
