Render issues using Take manager
Hi all,
A couple of issues really…and I’m hoping for some help to see if I’m doing something wrong in the settings:
1. I can’t get rendered images from the Take manager to export all elements in the same named file. I believe this is possible with a .EXR file, but not been able to get anything other than an Alpha? I would like a MultiMatte element to export with the file also.
2. And again with the Take manager when rendering out also using DR, I uncheck the ‘use local machine’ option and the alpha channel doesn’t export either.
The reason I use the Take manager is for two reasons:
- I have a lot of differing setups for the scene to export in one go and the VFB only renders one at a time (please correct me if I’m wrong)
- The VFB doesn’t use the take names and you end up renaming all of the exports (again please correct me on this)
Does anyone have any workflow improvements or solutions for these problems?
Mark
