Render Mask VFB not clearing after each frame
We ran a animation with Render Mask include/exclude enabled. There was only one object added to the include list. What seems to have happened is that the VFB wasn’t clearing after each frame so we would have that object overlapping itself in subsequent frames. Thoughts?
Hello
There is an option what to happen with the previous VFB image in animations - the default is “Unchanged” so the object is overlapping. If you set it to “Clear” - it will clear after each frame.
Yavor
Thank you! I was looking for that :slight_smile:
Where in the UI do I find this option? The link you provided has gone dead. I’m still using Vray Next.
It would be nice if by default it could be cleared for animations, while for stills it is probably more practical to keep the unchanged option.
Yes! And ideally you have one setting for Animation and one Setting for Stills. These would be saved with the scene, but default to clear for animation, saved for stills.
Weird, but I just rendered an entire animation with rendermask, and even though this setting was set to clear, the subsequent frames are trailing in the transparent areas during the entire animation. I use V-ray 5.2 in Max 2021.
The animation was submitted to Backburner, but the setting should follow the file right?
Can anyone confirm if it is working or not?
This is how it turned out.
This is what it should have looked like.
My settings
Ah, I just saw that this issue is fixed in the Hotfix! Never mind then… Thanks for releasing the hotfix so quickly!
Yep it is in the hotfix. Sorry again for the inconvenience.
Have you installed the hotfix?
Ah, sorry, I was confused, I thought the Update 2 was what you guys meant when you referred to the hotfix. Yes, after installing the hotfix the issue is fixed. Sorry for the confusion.
