I have to prepare a small scene for a realtime previz and I am completely out of the water with texture baking so that the problem is on my end is very well possible.
As of right now I am trying to bake a complete map on a simple box. (Settings are attached as an image.) My render settings are the new vray default as of 3.30.04
When I hit render within the render to texture box light cache starts to do its thing but when its finished max crashes with this warning: (see attachment)
The same happens when I try to use Brute Force / Brute Force instead of BF/LC.
I also attached the vraylog from after the crash. If necessary I can send the scene because since this is for a paying job I am a little bit under time pressure.
Use the VRayCompleteMap bake element… we really need to fix that at some point…
Best regrads,
Well now I feel silly. Thanks Vlado. Now it works. ![]()
