is there any proper solution to render out the Velocity Streamlines (available in the Phoenix Simulators / Vray Volume Grid - Preview-Tab) or even better get access to them as Splines?
I tried out a workaround by using TyFlow reproducing the streamlines. But the Streamline Preview is a way more straight forward.
not a perfect solution, but how about a viewport grab? You can disable the show box option in the Preview settings for the simulator, hide the viewport grid in Max and just save a viewport preview from Max.
No way to export them as splines yet, but this is a cool idea.
Out of curiosity - what would you use the Streamlines for?
Pardon my intrusion…
I work with air conditioning in my day job… wind currents blowing and recirculating from the AC unit into and around objects in the hotel room… if the streamlines could be animated and rendered, that could be useful for engineering / hotel development clients.
I am sure you could do it by using particles and then using Tyflow or even some scripts out there that convert particles to splines (PF Spliner I think was one and pFlowTM is another)
Chaos, give Svetlin and the gang raises. They rock!
