Render will not start
Vray works fine with a new project but when i open the attached .skp Vray will not start rendering.
Any help is appreciated.
Sorry fixed the file permissions…
Meet Google Drive – One place for all your files
Anyone? I really need to find out what is wrong with my file. I don’t even get an error so I don’t know where to start…
As a hotfix you could try to open a new file, and copy / paste the model into this file, to see if that helps.
Jorgensen
I suggest you first wipe vray data, extensions-vray-tools-wipe vray data..
Thank you all for your answers.
Materials were the problem. Deleting those everything works fine.
Hi andreas_kallis,
You are correct - specific materials in the scene seem to be the problem.
This does not change the fact we have to find what’s causing the issue and fix/handle it.
It has been logged in our internal bug-tracking system as SK-3378.
Regards,
Konstantin
Hi guys,
The issue has been located and fixed.
The fix will make it in the next update (you can expect it soon soon).
Konstantin
