Vray next random problem
please see attached, A was rendering from yesterday, B is what is happening today.
Open an existing file (that was working fine yesterday), open vray asset editor,
Render (same settings as yesterday), file will render.
Save file as new name, render it is fine
Exit sketchup, start Sketchup, start Vray asset editor, file will not render lights & lighting correctly.
I tried:
changing style to shaded
deleting recent components & materials
nothing works after I exit Sketchup.
I noticed that sometimes when I start Vray asset editor, in task manager cpu is at 60%+ for 5-15 minutes. Again this is simply opening asset editor, not starting a rendering.
Interactive rendering is off.
Everything was fine yesterday, then this morning is when the problems started.
I have not made any driver or other software updates in the past few days.
Any ideas?
Thanks,
Glenn
Vray Next & Sketchup 2019
8700k
RTX 2070 driver 419.67 creators
W10 1809 17763.379
I was able to find a work around to the problem:
I opened a new empty Sketchup file, then copy & paste (in place) a few items at a time from the old bad file into the new file. Geometry, materials, colors, lights, all with Vray information.
New file is working fine.
Glenn
Thank you for reporting this. Just wanted to let you know that the issue will not be reproducible in the upcoming update.
Kind regards,
Natali
