I am trying to render a load of curves but can’t seem to control the width properly…
The default 0.2 startWidth is too big so i set it to .05 but it rounds back to 0.1. This is still too big but if i set it to anything below .05 it just renders a 1 pixel line..
what I did in that case was I just took multiply/divide node and connected its out x to the start width, and used the precision value there instead. Its not very good though…
Strange, it works all right in my tests here (no “rounded” bug).
What version do you use ?
I have this :
VRay stable build 19902 (2.10.01) from Mar 10 2012.
Maya2012 64bit Subscription Advantage Pack, Service Pack1 (released on 2012/01/26)
Windows Seven 64bit.
Strange, in Maya 2012 it is doing the rounding only for display purposes. I did change the control to show 3 digits after the point though. You can download the nightly build from today if you have problems with this.
Actually in the latest builds we added a renderable curves set, so you can just connect all the curves that you want to render and control them from one place.
