Anyone here using RenderPal? I need a server that will enable multiple renders consecutively and read somewhere that RenderPal was recommended for use with Corona. I downloaded RenderPal and started through the manual, but the ‘easy to understand’ instructions appear to have been written by, and for programmers and IT pros. Anyone have any success setting up and using RenderPal? Or other render server?
I don’t really have any experience with that application unfortunately, but I would recommend you contacting their support and requesting simple instructions how to achieve the goal you are after.
I also do not know what exactly you need to do, but you can use Corona’s distributed rendering (DR) for “all machines are rendering one frame” jobs, or Autodesk Backburner for “each machine is rendering each frame”.
Guide on using Corona’s DR: https://coronarenderer.freshdesk.com/support/solutions/articles/5000501666
I use it for many years and is brilliant. But it’s no longer supported and I cant find a non-trial installer anymore. If anyone has one let me know!
