Repeated keyframes
I’m running into an issue when saving out my animation. I always get the same keyframe rendering in the beginning of my sequence and end. Like it’ll render 27 keyframe 0 and a similar amount of the end frames. How do I tell it to just render one frame and move on to the rest of the keyframes?
Could you explain in a bit more detail what you are rendering: for example, is it a camera movement recorded in Vantage itself or did it come from the vrscene? Is it a plain vrscene animation or you used the Vantage animation editor?
Could you also copy the SettingsOutput plugin from the vrscene file? It contains parameters about the animation range.
