I rendered a batch of cameras with Pulze Scene Manager, but wanted the overall resolution to be smaller as I was testing the setups.
I’ve set render settings in VFB to 75%, the resulting saved JPGs (common) were in the original resolution, but with the rendered image taking 75% of the resolution. (Can’t show the images because of NDA). But basically the resolution was still at the original 100%, but the render was at 75%, leaving the rest blank. The VRIMGs are ok.
I can reproduce it with basically any format that goes through the 3ds Max common output (jpg,png,tif). It most likely doesn’t happen with exrs/vrimg because (internally) those formats go through the V-Ray output.
In the docs, it’s stated that: This only affects V-Ray and does not affect the native 3ds Max test resolution setting found under 3ds Max’s Render Setup dialog.
So, it seems expected… Not sure what Vladi was talking about (the devs do not remember reporting this).
Anyway, I found a workaround for it to work in 3ds Max Native’s batch:
Use the Separate Render Channels output (Render Setup > V-Ray > Frame Buffer)
Use a “#” symbol in the name at the end
Save this script and use it as a pre-render script: slidertime = slidertime + 1f
We do 2. and 3. because otherwise the batch files will override themselves. The script only changes the timeline so that we have a different name for each render.
