Hello.
Is VrayEdges texture for bump not working or I am doing something wrong?
I’ve already tried it in Vray Next and in last nightly build of Vray 5…
Hello.
Hi @gagui ,
Just did a quick test here, seems to work as expected.
1 meter cube with a 1cm round edge:
EDIT: I see the problem “VrayEdges texture for bump”, use the method I used in my image, will do what you want. I used that method of edges texture in bump back in the day in 3ds max too, but now you have a node just for that, much better.
Best,
David
Great David!
Yes I’m coming from 3dsmax, that’s the reason I did it that way.
Thanks for the info.
