if I open a file at Rhino 6, than I doesn’t get the materials like at Rhino 5.
(Enscape 2.5.0.50)
-Micha
Rhino 5 - 6.zip (885 KB)
(Enscape 2.5.0.50)
-Micha
@Micha - I can’t reproduce this. When I open the project file, that you posted, in Rhino 6 the materials are shown.
They are listed as Custom Type materials in Rhino 6. If this is not working for you, wouldn’t this be a Rhino issue anyway?
Or have I misunderstood what you mean?
Very strange - first problem: I selected the front glass wall objects and at Rhino 5 the material is named “glass.doorwall”, but at Rhino 6 is shown “/Glass”.
I think, you are right, it’s better I ask the Rhino team, since this it’s basic Rhino functionality only.
Thank you,
Micha
@Demian_Gutberlet @Pete_Chamberlain I got no answer at the McNeel side yet but it seems to be a serious problem.
One year before I created a scene at Rhino 6. Today I opened to check it and I found, some materials got the “plugin” flag enabled at the object properties and are not connected to the material at the Rhino material editor anymore. A dark reflective plastic is a non reflective pink now. It looks like there is a problem with the plugin ID, old scenes setups are destroyed. I will send a file per email to Demian.
I got an idea now and disabled VfR from the plugin list and … all materials are like they should be. So, Vray cause material trouble at Enscape. Now I will ask at the right team to solve the problem. ![]()
Thanks for the project and heads up @Micha . Let me know in case you require any further information from us. ![]()
