Hi, I use rhino’s edge softening tool, (not fillet edge command, the one in the UI to set all edges of an objects). This used to work just fine for a long time but I realized that it is not working anymore for 2 weeks maybe. I tried to understand what can be the cause or if there is a solution on the internet but couldn’t find something. Are there any suggestions?
I use Rhino 7 / 8 WIP&BETA version and up to date v-ray version on windows 10.
We are aware of the issue with Edge Softening in Rhino 8, please refer to this forum post. I have also linked your post to the internal issue VRW-4000 and will notify you once it is fixed.
Hello @mackl ,
The issue with Rhino Edge Softening was resolved in 6.20.00 V-Ray build. If you are using earlier version please update to the latest one (you can download it here).
Thank you for the details @mackl , now I see what you mean. There is indeed an issue with what you describe, for more details please refer to this forum thread.
We are working on a solution at the moment, I will link your topic to internal issue number VRW-4450, so that once there is an update we will notify you.
