Hello everyone, please forgive me if the question has already been asked before. What I need is to simulate a river dragging objects and that they collide with each other. Is this possible or do I need some other kind of software? I thank you in advance for your response. Greetings!!
Hi thanks for posting. You could start with the Ice Cubes setup. You will find it in the Phoenix tool bar. This pre-set uses Active Body Solver and it should work in your case as well.
Hey,
You can also check a simple way of doing this here - https://youtu.be/mGAyh3uR89U?t=680
In order to make the objects float or sink you can play around with the density in the right-click Phoenix Properties menu of each object.
Thanks for your answers, finally i was able to do it. Thanks again!
