I’ve got a problem where my RPC people are walking on the spot when I use them with Vray. If I switch back to the scanline they move along the path. With Vray they stay in one position.
Has anyone else had this problem?
I have emailed Archvision for an answer, but if anyone already knows I would greatly appreciate it.
Thanks in advance.
Saul
NOTE: my ACM is not installed properly becaused I have just upgraded my machine. This may be connected, but I don’t know.
I think Paul was refering to VRay version 1.46.13, not what RPC version you’re using.
He’s right, according to the ‘what’s new / bug fixes’ section the RPC problem was fixed in 1.46.12. However I wouldn’t advise you to change versions mid project, espesially a leap from 1.09 to 1.46. There’s a bit of a learning curve with the new versions.
It’s just that VRay is a quickly evolving program and there have been a number of significant changes between 1.09 and 1.46. There are a million and one threads on this forum regarding the differences between the two versions.
It depends on the complexity of your project but if it involves animation or complex materials I think you will find it difficult to change mid project.
For what it’s worth, I find 1.46 vastly superior to 1.09, 1.09 wasn’t a bad product but 1.46 is a much more complete package and with the right settings its faster and more controllable. Definitely worth making the change when you can.
Yes, you need to put the IP address of the machine you are going to run the licence server (VRLserver.exe) into the dialogue box, press save then close and reopen max. You should then get a code which you must email to Choas to get a new licence code. A bit like the way Max licences itself.
It took only a couple of hours for me, depends how busy they are I guess.
But to go back to your earlier question. I think that if you try to change versions mid project, you’re going to cause yourself a lot of stress. So, yes, I do think you should go back to 1.09 untill your project is finished.
Like I said before I think 1.46 is fantastic but I would start using it on a small job that just requires a few stills. You need to re-make all your materials for a start and get used to the new settings.
Thanks for the humour, Dan. Much needed right now.
I’m afraid Jacko is not the flavour of the month at the moment. I don’t like the guy anyway, but when I got in this morning and found half the population of my movie moonwalking I dislike him some more.
I think I’ll take a look at people-n-motion and stick a couple of their demos in for now.
There’s nothing I should know about them is there?
Not as far as I know but I’ve never used them. I sure others on here have though, if you do a search you’ll find other posts relating to them. Should highlight any known issues.
