What is wrong with RPC
Hi everyone I’ve tried to do a simple scene with RPC in it, however when render is done the RPC person is somewhat twisted the upper half is facing away the camera while the lower half is facing the camera. How do you correct this.
Sometimes also when I insert the RPC people Max crashes.
Any advice is greatly appreciated, Thank.
By the way how do I upload my image?[/url]
I’ve been having problems with RPC but they all seem to be Archvision bugs not VRay, check that there are no instances
R2J2 I only have RPC in my scene. I’ve already tried deleting it and insert a new but it is still the same.
use the Img button.
mabey you should go to www.archvision.com and use their support.
RJ2J, It’s quite funny because when I use it with the default scanline renderer it is ok.
Any thoughts.
regards
try putting the person back in & if there is more than one camera I’ve had problems. but I’m not shure.
umm look in the Vray text…see if it tells you anything…
like i had a thing that one out of 100 rpc people I had …umm tammy …
had a bad image header…
i have this problem always when refletion is active, if i desabilite this option, the rpc is show correctly, but would be good that someone said a better way to correct the problem.
isnt “whats NOT wrong with RPC” a better topic
:smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile:
humm …I dont know :smile: …a empty topic :wink:
I’m getting really !#$!@#$off by the fact the problems are different every time I render.
i had same problems with rpc, but it renders correctly for me if uncheck reflections
I certainly believed that this is a compatibility problem. Which ever way someone has to look into it. :?: :?:
marina when I uncheck refections on RPC (Localy or in mass edit) ther refections are still there, does this still fix the problem or do I have to have the object properties refect/refract unchecked.
When uncheck reflections, the upper/lower half of image problem disappear, but you still seeing reflections (on wrong orientation). Maybe this coud be that Vray don’t receive the value of reflections from RPC, but I don’t know how solve it. :frowning: Some photoshop work
PS: I try to use RPC only when I have no time for make own images of “real” people, because looks a lot beter than RPC, so maybe other people work more frequently with RPC and know a solution for this :?:
Try a different RPC…
Try a different RPC… I had them go corrupt before…
also ya could try and pull the origionals off the cd …
I DONT LIKE THE REAL PEOPLE>>>>>
got to be somthing better …
I guess the problem at the moment is, whats better for animations than RPC? for now the only prolems I’m having is that the reflections flick on and off, not the people when you view then directly.
