RPC
I’m still having problems using Rpc .
Vray.log shows lot of overbrighed object.. and the final render is something very funny… red, green… and other very colored dots. Tried using options in rpc control panel.. the result is ..sometimes works, sometimes not.
Really seems a bug. ??!!
Anyone got the same?
3dsMax 7 (sp1), Vray 1.46.15
Marco
I had this happen to me ysterday with the RPC cars. Are you using light cache? I heard that might be the problem
make sure you go into the vray properties for all of your rpcs and uncheck receive and emit GI.
Thanks for the fast replies!!
@Czoog
I’m only using Irradiance map + QMC
I have cars and people and without them it renders very good… this makes me think that could be a “sort” of bug.
@Percy
hmmm… ive tried also that… i will try again, maybe i forgot some of them.
Best Regards,
Marco
As far as I remember there was some Reflection option in the RPC objects that needed to be turned on or off - not sure which one…
Hi Vlado,
Yesss i did it. Option is “Cast Reflection” , but i didn’t solve the problem because the result was a strange rpc look… btw i decided to insert people in post …
I will make tests and let you know what happens!
Thanks again,
Marco
I am also having error with RPC. Im using revit 2021+Vray52023. Log say unable to process RPC. Also mesh material not rendering as well. Previous Vray works fine but no chaos cosmos. Is there any fix? Thanks
Here is the log file…
Dear @nolibien_milla , hello.
To investigate further the mentioned V-Ray for Revit issues I have just opened for you a ticket in our system.
Let’s give us clearance and solve it one by one.
Please check your e-mail.
TS
