RT GPU Error 700, stops the render! cant use RT gpu after the error in any scene
hi, i am having this problem, it started today using 3dsmax 2018.
Everything was fine untill i placed itoo’s: forrest on the object with grass preset, i started the render and it automaticly stopped with this warning (look on image attached)
Then i thought it was some Forrest pack problem, i deleted everything of the forrest pack and tried again, it stopped the render again with the same warning.
I tried to merge objects into another scene and render again, it didnt help, this curda error happened again:(
I am using latest nvidia driver, i also switched to previous 388.13, but still this error appears and i cant render anything anymore on rt gpu. I think this is some kinda of a bug
specs: 1080 ti
vray for 3dsmax2018 3.60.04
i hope someone will see this, If you need anything else, just ask
Which ForestPack version are you using?
hey, it is the latest one, i think 5.4
everytime i place some preset vray gets messed up.
Even if I reset scene and dont use, delete FP vray wont render on GPU cuda anything.. I need to restart max to make it work again. lol
I figured that some presets work some dont, that is a problem for itoo forums.
The main reason why i posted this in vray forums is why does vray gets like this after i delete every FP in the scene? it should be fine and render normal geometry? is it suposed to behave like this or i am just noob
I’ve been trying to reproduce this with no luck here (Max 2018/V-Ray 3.60.04/ForestPack 5.4.1 and the same drivers as you). Can you send us a sample scene to support@chaosgroup.com with which to reproduce it?
hi miroslav,
I recorded the problem and sended the video with link on this thread to support@chaosgroup
Download the video to see it in hd quality, my preview in gmail makes it 360p and it is 1080p file
I did not send the scene because the problem also persists with a empty, new scene
.. i have update 3 from max2018 installed, forgot to mention this earlier, also regular grass preset doesnt create this problem, only some presets
Thanks Ivan. Will check it out and get back to you later.
