Save Enscape Scenes
Good morning everyone,
I was wondering if there is a way to save different scenes in Enscape?? I have them saved in SketchUp, But they are slightly different.
Someone knows a solution?
Thanks!! :wink:
In what way are they different? If you use the “synchronize views” feature, they should match, except the aspect ratio. Can you post screenshots, that highlight your problem?
I apologise for the late reply. Please find attached the same view in Sketchup and in Enscape.
Looks like only the field of view is different. Are you sure you have enabled view synchronization, which synchronizes the field of view automatically?
You can also try to adjust the field of view manually in the settings.
Interesting. I made the assumption that “synchronize views” would override the Enscape FOV to match SketchUp’s to synchronize the two. Its a bit un-intuitive in that respect, but that’s very helpful to know about. Thanks Simon.
@tedvitale.cg It is overwritten and fixed if you activate “Synchronize Views”.
Ahh, I mis-understood what you were showing here.
